Thankyou Scotsman. I am away from home at the moment so will check when I get back. Are these power modules easy to check I have a multimeter and experience with electronics and are they expensive / readily available?
They can be quite pricey, but trust me you will not need to meter it as it is probably blown and you will see the tracks are gone. Make sure you note the condition of the wiring connectors on the board before you replace as sometimes these get destroyed and you will need to replace individual wiring. If the wiring is in a bad state trace to wiring to see where it goes in case you have a secondary fault which has caused this.
