Indesit wd12, programme knob keeps clicking round
3 Sep 2009
Lancashire
Hi
When i set the washer going, the water comes through to the soap drawer but then the washer stops and the programme dial starts clicking round. i have tried resetting the dial, even turning off the machine at the wall but it still does it when i switch it back on. I have seen posts where people are saying about the light flashing so many times, with my washer the light is flashing 13 times . does any one have any ideas about what the problem could be? Please?
i found this advice on another forum but for a different model, would this information be right for my model? or could it be a number of problems?
:confused:
F13 is a failure of the thermistor (or temperature sensor) on the dryer. Part required
If you are not confident in your own abilities, engineer time. Check in Directories for a local UKW engineer, or pop your post code up and someone will pick up on it.
Whatever you do, pull the plug first.
The error does indeed relate to a 'Thermistor' fault (Part No: C00080767) I would get an engineer to check it out for you. It may be blocked with fluff for example.
You need to call in us experts It's NOT a DIY fix
Indesit WIDL Codes
See also Hotpoint WF & some WD, left hand lights from top to bottom or digital display.(next page)
widl codes - light flashing from left to right are numbers 1-4
f01 light 4, motor triac
f02 light 3 motor, jammed/ tacho
f03 lights 3&4 Ntc fault
f04 light 2. pressure sw stuck on empty
f05 lights 2&4, pressure sw stuck on full
f06 lights 2&3, N/A?
f07 lights 2&3&4 heater relay
f08 light 1. heater relay
f09 lights 1&4 eprom/setup error
f10 lights 1&3, pressure switch not sensing
f11 lights 1&3&4, pump/draining error
f12 lights 1&2, communication error
f13 lights 1&2&4, dryer ntc/ fan motor
f14 lights 1&2&3, dryer heater
f15 lights 1&2&3&4, dryer heater relay
f16 N/A
f17 light 4, door lock
f18 light 3 comms error (3 phase motor) power board
f1 and f17 share the same light
check the 2 wires are not broken on the top of the heater box 2 very thin blue/black wires they go to the themistor on the heater box. also check the fluff in the fan assy split the heater box
