Installing a consumer unit
3 Oct 2004
I wish to install a 6way MCB Consumer Unit in an older house that has been rewired within the last 10yrs, but the distribution board was not replaced.
I have a qualified industrial Electrician friend that will carry out the work. However the Main Fuse needs pulling to disconnect the tails and reconnect to the new unit.
How can I get the Main Fuse pulled (seals cut) and reconnected on completion without providing a Certificate of conformance to the new reg's. Clearly I do not wish to rewire the complete house at this stage.
Any views or pointers on procedure I could adopt?
Plonker
break seal, pull fuse, do work, replace fuse
no don't do that it is iresponsible for that to be mentioned on this site, it is ilegal, against the law and dangerous.
plonker, you have to ask your supply company. end of for you to follow other advise is dangerours, you do not have correct testing equipment etc, you could severly injur your self and whose advice would you have followed?, not mine that's for sure
Come on Andrew! Before pulling fuse make sure the CU is switched off and after pulling fuse, cover exposed live parts while work is being done.
I have always poked the seal wire back through the holes so it looks like it's still there.
guess thats why they have started using stainless steel seals instead of lead
If the unthinkable happens and a fire starts (even apparently unrelated), you can bet your bottom dollar checking the seal and for corresponding CU additions will be high on the list of a fire investigator or insurance assessor. A bit like having 1 pint too many, being in perfect control of a car, not being responsible for an accident but getting done for drink driving...
you just claim it was done by an electricain and you can't remember the details of who
thats ok then is it? blame some one else? ok then so hows about we all blame you? ;)
no don't blame anyone in particular
but don't admit doing anything either
