installing additional toilet outlet
Discussion in 'Plumbing and Central Heating' started by russellb, 17 Apr 2006.
  1. russellb
    17 Apr 2006
    2
    Thanks Received:
    Leicestershire
    Country:
    Hi
    Can you tell me how to connect an additional toilet outlet to existing underground existing toilet outlet.
  2. oilman
    16 Sep 2003
    7,975
    Thanks Received:
    27
    Country:
    Not unless you can say more about what your present situation is.
  3. russellb
    17 Apr 2006
    2
    Thanks Received:
    Leicestershire
    Country:
    Trying to connect upstairs toilet waste pipe to outside underground sewer pipe which comes from existing downstairs toilet which in turn leads to main sewer.
  4. Softus
    21 Oct 2004
    19,558
    Thanks Received:
    9
    Country:
    Well, replying at the same level of detail as your question, you dig thr gound up using a spade or mechnical digger, you run the soil pipe vertically downwards, connect it to an underground pipe that continues downwards to a sufficient depth and then turns towards the position at which you want to make the underground connection, then connect it to the existing underground drainage, using a connection that you place in an inspection chamber or that is combined with one, having bedded the underground pipework on the correct bedding material and backfilled with the correct backfill material.
    And you do all of this under the control of your LABC, because it's notifable work.
Loading...
DIYnot News
Similar Threads
  1. Djvanok
    9
    235
  2. bluebaron
    10
    217
  3. Rredwin
    3
    108
  4. Adriandiy
    103
  5. cuttertree
    266
Share This Page
