installing airvents
12 Aug 2014
Argyll
Hi, I will be installing air vents into the exterior walls around my house. The problem is the walls are 3ft thick mixed stone and rubble. There are a few places where I can find spots to dig through and I can keep the air flowing around the sub floor o.k. but the hire places just give me the old slow head shake with the tut tut tut when I ask about cutting or drilling through. Any advice? Thanks, Jonny.
I have a rock and rubble house, walls 24" thick. Knock out a suitable stone on the out side and inside. then fish out enough rubble to give a clear air passage. Line the hole with a tube of visquerene or similar plastic. Make good outside with air vent padded out with mortar and stones.
When you drill right through the wall, you will hit some snags, as you pierce the skin nearest you, you will hit the side of a super sized pebble, this will deflect or jam your drill. If by waggling the drill about you get it to go past the loose fill and drill through the other skin, you will find that on withdrawing the drill, the loose fill will drop and obstruct the path between the two holes in the skins. Hence biting the bullet and start of by making a hole you can get your hand inside to remove the loose fill.
Frank
