Intermediate Switching
30 Jun 2009
Londonderry
I am puzzling myself over whether an intermediate switching set-up will function correctly, if the the perm live and switch line (T&E) form the light was pulled through to the intermediate switch with both 3 core strappers being there and terminating the perm/switch line at 1 and 2 way of intermediate.
My head is saying it would in theory.
Do you mean run the switch wire (perm live and switch live) to the intermediate switch?
Yes, that will work. Done this many times where it's been more convenient to do so.
If you were to draw a simple circuit diagram (like a college-type diagram) you will see it's effectively no different to running the switch cable to one of the two way switches.
No nor have I. But I can see it could be easier - particularly if the intermediate is nearest to the lights
Yes, three core strapped across the three switches as normal. but the switch wires from the light fitting coming to the intermediate. Then terminating the stappers as normal and perm to 1 way and switch line to 2 way of intermediate.
That is the reason I ask, it would be much easier to pull the cables through this way.
I have the configuration in my head, and I believed it would be okay. Just because never done it this way, an element of doubt.
Thanks for input, can sleep easier.
Just to help you sleep really well, where you would usually connect the switch cable to a 2 way switch using L1 and L2, you would use the corresponding L1 and L2 (on one side, say the top for example) of the intermediate.
If you see what I mean.
I too agree it would work, providing both L and S/L are obviously on same side of intermediate switch,I suppose in fact, if tubed and wired in singles, you could put the LIVE in the two way switch and S/L in the intermediate other strapper if it was convenient
As above, it would be no different than connecting at one of the 2-ways. If you really wanted to, you could also wire the "conventional" method by splitting the common where it runs through the intermediate box and connecting to the live & switched live of the twin.
Look at it this way:
Normal three way switching - 2W,Int,2W switches with switch wires at one end.
Would it matter if you connected them at the other end?
It doesn't matter where you connect them.
No Int. here but put it anywhere.
