I had a damp patch on an internal single brick wall between the lounge and the hallway. When it was damp outside the damp would be more apparent upto 18" or so from the floorboards.
A few weeks ago I lifted up the boards on both sides of the wall and installed a new plastic DPC under each brick working along the wall brick by brick. The joists were originally packed underneath with tiles/slates etc to make them level (as opposed to them sitting on the old DPC) so I did the same and made them all tight. Although the joists looked a bit damp at the ends I thought they would be passable, cleaned all the rubbish out of the floor cavity and nailed the floorboards back down.
The walls still showed the damp but I was expecting that to gradually dry out after a few weeks as the new DPC took effect.
But now several weeks later the damp is still there on the walls and seems to get worse when its raining outside. So today I lifted up the boards in the lounge and knocked off the plaster on both sides of the wall to check the bricks. They all looked dry to me (see photos)
I have checked the DPC I installed and its OK, nothing is straddling it so it should be stopping the damp rising and the bricks below it do look damp, above it they look dry.
So my question is: does 1930's plaster hold the damp once wet and hence why I should have knocked it off in the first place, are the bricks damp and will take time to dry out (if at all)
Should I knock the bricks out and put new dry ones in or could it be that the damp is coming along the joists from under the hallway and thus is above the new DPC (I haven't lifted all the boards from the hallway) but the ends going into the brick wall look dry on top to me.
I had planned on putting plaster board over the bricks and then skimming them to get the finish as an easier way than doing Browning and then thistle.
Have I done anything wrong or missed anything ? Do I need to remedy anything else first before doing the plasterboard ?
thanks
(you can see there is a radiator pipe sticking up in the hallway photo but I checked underneath and as far as I can see it hasn't leaked and caused the damp)
Uploaded with ImageShack.us
thanks
