Hi
I have just moved into a house with a Gloworm Micron Boiler and a Drayton RTS1 Room Thermostat. The boiler works fine - hot water and central heating both work. But there is no click when the dial on the room thermostat is turned and hence when heating comes on it just gets hotter and hotter!!
I have taken the cover off the Room Thermostat and it is wired up to the mains correctly (although I haven't checked whether the wires are actually carrying a current). The house is only 2 yrs old so I am assuming the problem is just a broken Room Thermostat. Can anyone confirm this is the likely cause or otherwise before I buy a new RTS1 unit.
Many Thanks
Karl
Many Thanks
Karl
