Hi experts,
I've been getting quotes on a replacement roof on a 30's semi and wanted to check something I've been told.
We have 4" joists and ceilings that are vaulted round the edge. To meet building regs and stop condensation we need Celotex between joists in the eaves. All ok so far.
Here's the question: one roofer says that we need to have 100mm insulation which then means battening all joists on the outside to lift the roof height and maintain a 50mm air gap. The other we've spoken to says 50mm insulation is fine.
My preference would be to leave the height as is, since otherwise we end up with a joint between us and next door. So - will building control really expect the roof height to be raised or do the regs allow make allowances for older houses that can't meet U values without this kind of work.
Thanks,
James.
Thanks,
James.
