Is this DPC lapping?
18 Aug 2010
London
Hi
I've heard you guys mention that the dpc on an extension should be 'lapped' to prevent thermal bridging.
Below is a pic of my existing house on the left and the dpc level built for the extension on the right. Is the black material that's been folded into the existing dpc enough to satisfy this 'lapping' adequately?
Many thanks
Horrendous brickwork and lousy coursing up from concrete up to dpc.
Hi Noseall
Are you talking about the existing building on the left or the new bit on the right or both?
The brickwork on the right is too high and should be 10mm mortar joints, even the photo below is not that good but acceptable, make it easier for tooth brickwork
The lap in the dpc is OK; it's nothing to do with thermal bridging but just keeping the damp down.
Yes, brickwork is a bit rough but is it to be covered up and what's going on lower down in the pic? A wider-angle pic taken from further back would help.
Thanks Masona.
The pic is of the rear of the building. They have got the level of the new and old bricks perfect at the front of the building ie facing the street. The original bricks facing the front are imperial size but those at the back metric.
So could it be that because they've had to build against imperial bricks at the front but metric bricks at the back that we've ended up with this situation?
Thanks for your help
Is this possible indus :?: I'm trying to understand how you've done the dpc
Best to check with your BCO, I didn't open up my cavity as long as I install a vertical dpc
Hi Tony, just to be clear are we talking about the engineering bricks on the left? If so then yes they will be covered by a plinth. The brickie asked me this.
Which part of the work is 'horrendous' and why?
Below is a wider shot
Hi Tony, just to be clear are we talking about the engineering bricks on the right? If so then yes they will be covered by a plinth. The brickie asked me this.
EDITED BECAUSE I ACCIDENTALLY WROTE THE ENGINEERING BRICKS ON THE LEFT, I MEANT RIGHT
Hi
I've posted additional photos, is anybody going to explain what is so horrendous, lousy and rough about the dpc level brickwork?
