Lighting in an attic space - 2 lights and one switch.
Installed by Mr Bodge-it (previous owner) -trying to tidy it up a bit - ie replace the bent nails used to hang the cables with cable clips....and put insulation tape over connection boxes
Switch is a metal one surface mounted - a power cable feeds into it and cable out to light no 1 (and then another cable from light 1 goes to light no 2)...the cables are stripped back too far and so the individual wires are visible on the outside ...thought I'd shorten them a bit but when I opened it up I found something I've never seen before...
Inside the lives (red) are attached to the switch (normal screws and terminal things), the neutrals are twisted together and kind of screwed into a yellow cone shaped plastic thing that just sits loose inside the switch case....I've never seen anything like it but it doesn't look like a random bit of plastic ....
(the earth wires are cut off in the cables)
Is this ok? Not sure I like the fact that the neutrals aren't firmly attached to anything...
