We've had two pairs for timber patio doors and frames made. They are now wood preserved, knot primed, paint primed and first coat of exterior gloss/satin. The 28mm DG glass is in the shed.
Local building control are informed for the privilege of £169…
It's a 20 yr old extension, fenestration not changing, damp course is directly below door sills (not ideal but little option).
I'm reasonably handy but never removed or installed frames/doors before. Is there anything to look out for?
I'm probably going to apply the final exterior coat, strip out the first old frame, 'slot in' the new, screw it in, fit the glass on matchsticks with supplied low mod silicon and primed wooden beading, pin and paint over beading and edge of glass, seal around the outside with frame sealant and then paint and finish inside…. What can go wrong
