Equation
Volume (m3) = kg Required (kg) / Variable a (kg/m3)
Or
kg being Delivered (kg) = Variable a (kg/m3) x Volume Ordered (m3)
Or if you buy by weight:
Weight Required (kg) = Depth of Sand Required (m) x Surface Area of Room (m2) x Variable a (kg/m3)
Or if you buy by volume:
Volume Required (m3) = Depth of Sand Required (m) x Surface Area of Room (m2)
Where ‘Variable a’ for Sand is:
Sand, wet 1922 kg/m3
Sand, wet, packed 2082 kg/m3
Sand, dry 1602 kg/m3
Sand, loose 1442 kg/m3
Sand, rammed 1682 kg/m3
Sand, water filled 1922 kg/m3
Sand with Gravel, dry 1650 kg/m3
Sand with Gravel, wet 2020 kg/m3
Hence for your example of 800kg:
Volume (m3) = 800kg / 1922 kg/m3
Volume (m3) = 0.416m3
Volume (m3) = Less than half a cubic meter of wet sand
