hi - I'm a new poster here so bear with me....!
I'm fitting a new kitchen and (as I see many here discover), there is a lot of wiring to sort out first and this becomes involved...
Basically the kitchen used to have one of those cooker supplies high on the wall ,which has been since been removed, but the 4mm wiring ( which looks recent) extended to serve 4 TSOs as well as an oven and a light.
I intend to reinstate this 32A supply ( 4mm I think it is) as purely for my double oven. I will then install a whole new ring main in 2.5mm connected back to the fuse box ( old type without RCD ) to serve most of the kitchen. ( but not dishwasher or washing machines - I haven't investigated those) The new ring will run down the gable end of the house in plastic conduit.
I plan to do most of this work myself, calling in a sparks to certify.
My question is - is this a reasonable plan and if so do I need to replace the fuse box? It looks about 25yrs old with mostly old fashioned fuses but with a couple of Wilex (?) MCBs added in by someone. There is just one spare position available for my new kitchen ring main.
Thanks in advance
Richard
Thanks in advance
Richard
