Lead pip replacement - stop tap position...
1 Jul 2016
Hi all,
I am replacing the lead pipe in my house alongside a new rear extension. The pipe runs through the garage then around the back of my property coming in to the kitchen at the rear where I am building the extension.
I am going to dig a trench from the road, through the garage and then coming in to the kitchen from within the attached garage (single skin).
I just want some advice on whether I should dig down and run ducting under the house foundations and in to the kitchen that way or whether I can run the stop tap up the wall inside the garage and then drill through the wall in to the kitchen to take the pipework in that way. This is my preferred option as I want a water supply to the garage too.
Hope that makes sense!
James
Water supply pipes outside need to be at least 750 mm down.
It may be better to bring up your new supply inside the garage and through the kitchen wall. Less digging!
Tony
Thanks a lot Tony that's great, I was hoping I could do that!
Do I need to insulate the pipes that pass through the wall?
In theory yes! Also where you bring them up into th egarage.
As the garage is unheated, you need to put regulation thermal insulation on the pipe inside the garage!
Tony
