I've posted this query here first, because I think that plumbers may have come across the problem before.
I've bought a small 1930's terrace. New CH and boiler gone in months ago. Most if not all pipework is new. System runs fine, no pressure loss. Heating is not run very much because the house is naturally fairly warm, although it is prone to cold spotting.
I noticed that the surface of some of the floorboards in one upstairs room have marks that suggest a water leak, so I lifted the boards. The boards appeared dry underneath. I did find definate traces of water on the ceiling (top surface, underneath floor). I could find no water on pipes themselves. I wrapped some pipes in newspaper and checked later, but bone dry. One piece underneath a pipe did develop a very small wet patch.
This is where it gets weird.
The marks on the floorboards do not necessarily tally with where the pipes lie. Even stranger, where I found the wettest bit was where there are no pipes at all.
So, where on earth could the moisture be coming from? At first glance, it's a leak, yet I cannot pin anything down and there are contradictions. Is it possible for cold pipes under the floorboards to drip condensation? The house is prone to some quite cold spots, and as I say, the heating is not run often.
