LED strip on a curve
14 Sep 2006
Liverpool
Been asked to fit a a strip, or strips of LED around the curved 'face' of a display sign.
Having seen that LEDs have become so ubiquitous of late, I thought it shouldn't be a problem. However looking into it, I find that the strips of LEDs can only run in straight lines, whereas this sign panel is oval with a radius in the region of 500mm.
The only alternative would be a 'rope-light' type which is not really the right look, more Christmas decs, I'm sure most would agree.
Does anyone know a solution to running LEDs on a curved face?
Rather depends whether it is indoors. The LED strip can be cut at regular intervals, so you could cut and join.
(My use of these involves putting a straight clear plastic tube over them (SOIC IC carrier) making them easily cleanable and reasonably waterproof, but this will be harder for a curved strip.)
SNM, were you able to figure this out? I'm working on something similar and haven't found any flexible LED strips that can be bent along the face of the LED.
No, I gave up on it - think the shop has since closed down
Not looked into 'LEDs on a curve' since, however it would still be good to find a solution.
These strips will bend either way, just bought some for a little project:
http://www.ebay.co.uk/itm/2-X-24-RE...2V-/280600457132?ssPageName=ADME:L:OC:GB:3160
