lock in
Discussion in 'Windows and Doors' started by cras7033, 15 Oct 2007.
This topic originated from the How to page called Cylinder nightlatch.
  1. cras7033
    15 Oct 2007
    Thanks Received:
    Country:
    Hello,
    I\\\'d like to know whether there\\\'s a way to tample with a nightlatch so that once the door is slammed shut, it can no longer be opened from the inside of the house (turning the knob) but only from the outside, using the key?
    Thanks in advance,
    Cras
  2. yandownie
    12 Aug 2007
    97
    Thanks Received:
    Merseyside
    Country:
    it can easily be done on any nightlatch really,only problem is that then it becomes a possable fire hazard as you shut off a means of escape,possably even breaking the law depending on the location of the door?
    dare i ask the reason for this idea?
  3. JohnD
    15 Nov 2005
    43,871
    Thanks Received:
    1,956
    Perth
    Country:
    If you have a door with glass panels or a handy letterbox, it is usual to fit a nightlatch that can be operated in this way, to prevent some of the easiest ways of making a forced entry. It can be operated with a key. they are sometimes called "double cylinder nightlatches" as you have a key cylinder inside and out.
    It should only be deadlocked when the house is unoccupied, because of the need to escape in an emergency, as yandownie says. You can't rely on being able to find the key when the house is full of smoke.
    If you want to secure it at night, a large bolt or chain is better, as you don't need a key to escape.
    Since nightlatches are usually quite weak and insecure, if you are thinking of keeping burglars out, it is better to fit a deadlock as well as the nightlatch. this is much more secure, and having two locks on the door makes it more difficult to force open. Preferably fit one of the locks a third up from the bottom of the door, and one a third down from the top.
    Again, you should only lock the deadlock when the house is unoccupied.
  4. imamartian
    23 Sep 2007
    8,994
    Thanks Received:
    54
    Derbyshire
    Country:
    I have a similar requirement here, reason being is i have three small kids, and i can't be sure they would turn a key, or put a chain across when they come in, therefore anyone could gain access when they come to the door.
    So for a nightlatch with a knob on the inside, and a key on the outside would be perfect, but can you do this on a uPVC door?
    (and cras7033 sorry for hi-jacking your post :) )
  5. JohnD
    15 Nov 2005
    43,871
    Thanks Received:
    1,956
    Perth
    Country:
    'course you can
    [​IMG]
    instead of
    [​IMG]
    but on wooden doors
    [​IMG]
    not
    [​IMG]
  6. HandyHands
    6 Dec 2005
    545
    Thanks Received:
    16
    Derbyshire
    Country:
    The above still relies upon the child turning the thumbturn to lock the door. There are models of multipoint locks that have a nightlatch function, which disables the outside handle once closed, and requires the key to open from the outside. The inside operates as normal. This would require a replacement of your mechanism, and probably the frame strikes - not a cheap option.
    Example: http://www.buyourlocks.com/product_details.php?pid=1089
  7. imamartian
    23 Sep 2007
    8,994
    Thanks Received:
    54
    Derbyshire
    Country:
    That looks great, but is it a nightlatch - am i understanding this correctly? i want it to be locked when it's pushed to... and with no turning of knobs or keys :rolleyes:
    thanks
Loading...
Share This Page
