Loft dripping wet
25 Feb 2010
Durham
Last year after having the bathroom re-fitted and halogens installed i noticed beads of water hanging from the roof membrane anyways after realising
it was the heat from the bulbs i swapped to leds which did work and the problem cleared up anyways i just recently had the ridge tiles done but there was no air vent fitted a long story so i noticed taking the tree down the water beads returned it feels cold in the loft so i approached the lad who put the ridge tiles and we are now gonna fit soffit vents not wanting to disturb the ridge tiles we are gonna 4 in total one in each corner would the vents clear the problem cheers will
Ideally you need high as well as low level ventilation.
If the low level vents dont improve matters you can install tile vents a couple of courses below ridge.
