I fitted my first mortice lock yesterday and made the hole slightly to big. I can screw the top screw in but there is nothing to screw the bottom hole into it I have tried going in at an angle but no luck.
Can I fill the hole with something and screw into it, Could I use no more nails?
Or should I try fit a small dowel or matchsticks then glue and screw?
Any help would be good.
Thank you.
Thank you.
