Magnaclean Fernox Tf1 & Spirotech. Agree with the review
Discussion in 'Plumbing and Central Heating' started by sparkyshark, 1 Dec 2011.
  1. sparkyshark
    30 Aug 2008
    138
    Thanks Received:
    Country:
    I've done a few searches and was going to go for the spirotech until I read the below review (independent tests apparently)
    Any experienced views welcome... :) Out of the lot via our plumbing merchant the spirotech is coming up the cheapest at £88+vat.
    http://www.buzzheating.co.uk/Blog/?p=355[list=][/list]
  2. 45yearsagasman
    14 Mar 2010
    5,894
    Thanks Received:
    1,036
    Norfolk
    Country:
    Apart from the earlier problems with leaks the Magnaclean is IMO the best system filter. I have had one fitted to my system in excess of 18 months and the results are superb. No suspended magnetite gets past the very powerful magnet. The isolating taps have been improved and the seals pose no problems. The only drawback is that the 28mm is a bit of a lump.
    I have attended systems with other filters fitted and none of them match the Magnaclean. I shall wait now for the incoming flak. :)
  3. Charnwood
    29 Apr 2011
    3,579
    Thanks Received:
    512
    Country:
    The Magnaclean Pro is magnetic and, as such does not catch non-magnetic debris as well the others do. They state effective magnetic and efficient non-magnetic filtration
    Well, not unless you fit the just-released retrofit Sheath Upgrade which is said to improve non-magnetic filtration.
  4. Hufty
    17 Dec 2010
    608
    Thanks Received:
    137
    Yorkshire
    Country:
    Seychelles
    Have trialled the spirotech and the magnaclean on the same system (ie my own). Although the spirotech is a solid bit of kit and won't fail now or in ten years, it doesn't catch anywhere near as much crud. I do hope they've sorted the leak problem on the magnas as I've gone back to using them. The new sheath thing seems to work - opened it up to see if it had caught anything on a recent job and found a blob of solder in it. :oops:
  5. Whitespirit66
    15 Dec 2007
    8,011
    Thanks Received:
    753
    Bristol
    Country:
    What Hufty said is reinforced by a recent product test I saw. Can't remember who carried it out. The Magnaclean came out top for trapping magnetite. The Spirotech was praised for solid construction, but performed worst by a long way, although it also filters non-magnetic debris. The second best was the Fernox tf1, but where it excelled over the Magna was that it can also filter out non-magnetic crud.
    I have been put off of Magnas because of too many past problems, so still don't fit them. Time will tell if they have improved. I was fitting Spiros, until the poor test results, but now only use Fernox tf1, as they offer the best of both worlds, ie. good performance and non-magnetic filtration.
  6. mickyg
    24 Aug 2005
    15,998
    Thanks Received:
    3,319
    Cornwall
    Country:
    That test was commissioned by Adey who manufacturer the magnaclean, that makes me suspicious! although having said that the results are not surprising and also bare in mind the test was with the spirotech not the magnabooster, who knows if it makes much difference. I would say the maganclean is most effective, spirotech best build quality and the TF1 fits nicely between the 2. What i dont like about the magnaclean is well, alot actually, firstly to clean it you need to operate and rely on 2 iso valves(history of leaks), then you have to remove the lid, which disturbs a seal(more leak history) and often the lid is so firmly wedged on you have to put an abnormal amount of pressure into undoing the thing, and then if its not dead straight you dribble water all over the floor. In contrast the TF1 you remove the dry pocket magnet and open a valve into a bucket, easy. The valve is the only thing you distrub and if it ever lets by you can pop a washer inside the cap or use a combi fill loop cap. I dont think the spirotech catches much , so for me TF1 easy decision. Going back to magnaclean is like going back to Ideal, some people are a glutton for punishment :D
  7. Jordon
    18 Sep 2008
    614
    Thanks Received:
    95
    Bournemouth
    Country:
    Tf1 gets my vote, but magnaclean twin tech does intrest me more over the standard magnaclean.
  8. David937
    7 Aug 2008
    1,063
    Thanks Received:
    49
    Farndon
    Country:
    I haven't read/heard much on here about the Twintech, do many people use them?
  9. Dan Robinson
    1 Jul 2007
    43,967
    Thanks Received:
    7,136
    Hertfordshire & London
    Country:
    Don't get on with them personally...
  10. sparkyshark
    30 Aug 2008
    138
    Thanks Received:
    Country:
    Is there any truth in the findings of this review with regards to cleaning the TF1?
    http://www.ultimatehandyman.co.uk/forum1/fernox-tf1-or-magnaclean-filter-t26859.html
    I was near 99% on the magnabooster then further reading swayed me to the TF1 followed by the MagnaClean Professional and now I’m thinking the TF1 again.
    Need to make up my mind so that I can order one up tomorrow.
    It’s going to be used on my Potteron Kingfisher 2 (28mm) return pipe.
    In summary:
    Magnaclean picks up the best Magnetic particles, though doesn’t pickup normal non magnetic dirt.
    Has the highest trap (dirt) container. Though many reported incidents of leaks. Leaks may have been resolved with modifications. I.e. better seals, new isolation taps seem to have changed from red to black.
    TF1 picks up both magnetic and non magnetic dirt, and seems to be fairing well from installers, with low reports of leaks and if any possibly due to not fitting correctly coloured seals.
    Spirotech Magnabooster solid in construction, picks up both metallic and non metallic but is questionable in the collection of both, also has a smaller collection trap.
    Twintec out as no 28mm version is available.
  11. mickyg
    24 Aug 2005
    15,998
    Thanks Received:
    3,319
    Cornwall
    Country:
    not had those problems. I've checked a few I've emptied and they seem to clear out ok.....and to fill the thing up in an hour :eek: I think thats a system that needs more than a TF1 !
    Also in terms of emptying it, it does have a 1/2" thread on it. If a plumber cant think of something to attach to it.. :rolleyes:
  12. Jordon
    18 Sep 2008
    614
    Thanks Received:
    95
    Bournemouth
    Country:
    To add the newer magnaclean does have a collector for debris now at the base. But still a vote for the tf1 more addaptable to fit too
Loading...
Share This Page
