Last of several questions on work I need to get done (by a professional), thanks for answers to date.
I think I've got my head round what is required and why, gas & water bonded to main earth terminal, but I'm not sure if what I have in place is up to the job.
I had a new boiler installed recently (moved into loft) and the electrician brought in by the builder has bonded the gas pipe just after the meter to the earth terminal and also run an earth cable from there up to the loft where it looks like it bonds ...mains water supply(combi boiler)/hot water/CH.
So there's about a 60' run between the bonding and the terminal.
The 'entry point' for the water is in a corner behind kitchen cabinets and it's not accessible (boxed in/under floorboards and flooring) until it hits the loft so bonding any closer would be a major pain though of course safety is no1 priority.
Any comments on what (if anything) else I need on the main bonding front and if req'd any ideas how to get it done without ripping the kitchen apart would be MOST gratefully received.
