I have 8 Ohm speakers which I want to keep, I intend to buy a new hifi, will I have to make sure it will be compatible with the speakers or can I buy any old setup?
Assuming we are talking modern solid state amplifiers (apparently valve amplifiers were fussier) using a higher impedance speaker shouldn't generally cause any problems (though it will reduce the maximum power output a bit)
