Meter tails in cavity wall
Discussion in 'Electrics UK' started by cider, 3 Jun 2011.
  1. cider
    25 Jul 2008
    4,780
    Thanks Received:
    806
    Bristol
    Country:
    Hi. Can someone please tell me if new replacement meter tails should be run in a flexy conduit in the cavity.
    Many thanks
    Cider
    To clarify, if in the cavity.
  2. ricicle
    14 Sep 2006
    6,344
    Thanks Received:
    382
    Gloucestershire
    Country:
    Cables should not run along cavities in walls !
  3. Lectrician
    18 Jul 2004
    8,163
    Thanks Received:
    351
    Devon
    Country:
    With the excepetion of meter tails ;)
    They should be installed with care so as to prevent damage - ideally installed as the wall is built. Fairly easy to drop in if the meter box opening is cut out but the meter box not yet installed.
    The NHBC also detail meter tails as the only cable permissible to be installed in a cavity wall.
    typos corrected...
    • Thanks Thanks x 2
  4. cider
    25 Jul 2008
    4,780
    Thanks Received:
    806
    Bristol
    Country:
    To make it clear this is an upgrade of tails whilst fitting new cu. The existing ones were in the cavity Verticaly (about 1.5 m) between meter box and cu but not protected in any way. I've run new ones in flex conduit and going to protect them with rcd at meter.
  5. RF Lighting
    31 Mar 2006
    18,917
    Thanks Received:
    1,183
    Leeds
    Country:
    Why??
    How do you plan to achieve compliance with regulation 314.1 with that setup?
  6. cider
    25 Jul 2008
    4,780
    Thanks Received:
    806
    Bristol
    Country:
    Which part
  7. RF Lighting
    31 Mar 2006
    18,917
    Thanks Received:
    1,183
    Leeds
    Country:
    (i) for starters.
  8. cider
    25 Jul 2008
    4,780
    Thanks Received:
    806
    Bristol
    Country:
    Think it would hazardous and inconvenient to drill through a 100amp cable
  9. Lectrician
    18 Jul 2004
    8,163
    Thanks Received:
    351
    Devon
    Country:
    That doesn't make sence.
    The reg is dealing with the hazardous nature & inconvenience of the entire supply failing, plunging thw whole house into darkness while you are climbing the stairs, moving a fat fryer etc due to a dodgy kettle for example.
    Your RCD at the origin is in deviation of this regulation....
    You cannot place a 30mA RCD as the mains switch of an installation, and should not be placing such kit inside a meterbox anyway.
  10. cider
    25 Jul 2008
    4,780
    Thanks Received:
    806
    Bristol
    Country:
    Who said it wad 30 ma
  11. holmslaw
    12 Dec 2006
    5,841
    Thanks Received:
    400
    Country:
Loading...
Share This Page
