Mira 415
28 Apr 2006
Tyne and Wear
Water is coming from under the (ceramic)shower tray in one corner. It's not the drain. I regrouted the tiles and sealed the inside of the tray. Could it be a pipe that brings the water into the shower cubicle and is it a do it yourself job to remove the mixer unit and check if the water is somehow leaking from behind the tiles?
415's do leak after a few years, but water comes out of the front afaik. The visible parts do remove fairly easily - sorry can't remember the details. You should then be able to see some of what's going on in there. There's a refurb kit with O rings etc for £10 or so.
