Mould under bathroom lino
16 Sep 2010
Wolverhampton
I lifted a small area of lino in our bathroom (in a bungalow) because I kept feeling a small hard lump under foot. I was shocked to find that the floor in the area where the lump was was covered in patchy black/brownish mould. The underside of the lino was also filthy with mould-like stains. Neither the floor nor lino were what you would call wet, only very slightly damp, and there was no noticeable damp smell in the room.
We had a new bathroom 2 years ago which involved chasing out a channel in the floor to sink a waste pipe leading from the shower to the outside. The floor was also reskimmed using the correct compound prior to the lino being laid. The problem patch is an approx 2ft square area either side of the pipe channel. I have not removed all the lino, in case I can't re-lay it back, but the floor does appear lighter in colour and dryer in the area immediately beyond the dark area. The back of the lino also appears a normal cream colour in the unaffected area. I was able to "smooth out" the bump in the floor with the gentle use of a hammer, but I noticed that the hammer head left slight impressions in the floor surface where the lump was.
Is there a slow leak from the shower waste pipe? Or any other possible cause?
Many thanks for any advice.
