Multiple cables to outside of house - what's the best method
Discussion in 'Audio Visual' started by valve90210, 8 Apr 2013.
  1. valve90210
    19 Jan 2011
    23
    Thanks Received:
    Kent
    Country:
    Hi All
    Having recently moved into a new house (semi-detached), I'd very much to get network cables run to every room as we have so much kit which wants to be networked and the number if only going to increase as time goes on.
    My plan is to have the modem/router installed under the stairs, which are next to the outside wall. This would then allow me to run the majority of the network cables round the outside of the house which will make it much more simple to run them to all the room and into the positions I want without having to lift carpets etc.
    This should be fairly simple for the most part as it will be a simple hole drilled into the wall and sealed up one the cable is through. but I'm not quite sure what to do at the main point of exit under the stairs as this will need to be a fairly substantial hole in order for me to run several cables out but obviously I don't want it to look a mess, nore do I want it to be draughty.
    Has anyone else done this, if is so how, and or can anyone suggest any suitable methods (ducting?)?
  2. ChrisFrost
    26 Aug 2009
    1,025
    Thanks Received:
    213
    Cheshire
    Country:
    Have a look at weather-proof adaptable boxes. They come in various sizes. It's the sort of thing that the mains sockets would be housed in if tyou were fitting outdoor power. You can have one large hole on the inside back plate for the cable bundle, and then a series of smaller holes radiating out from the side walls. Scroll down on this page
    Now, I wonder what the alarm companies do? ;) ;) ;) :mrgreen:
  3. Belle427
    16 Jan 2006
    2,739
    Thanks Received:
    262
    Cardiff
    Country:
    cant help thinking this will look terrible but it may be unseen?
    make sure you use the compression glands to give the cables the weather seal they require. If you drill a hole in the back of the box its ip rating will be compromised so a bead of decent translucent sealant around the edge of the box to wall contact area is a good idea too.
  4. SimonH2
    4 Nov 2010
    3,902
    Thanks Received:
    440
    Cumbria
    Country:
    Also consider that standard network cable isn't waterproof - over time the UV will degrade it, moisture will work it's way in, and it'll fail. Usually lasts several years though.
    You can get outdoor cable, but it costs a bit more, and the sheath is "quite a bit harder".
  5. Sam Gangee
    24 Jan 2003
    1,845
    Thanks Received:
    282
    Cheshire
    Country:
    This is absolutely true but a good coat or two of decent outdoor paint will at least double its life - more if you repaint it periodically.
Loading...
Share This Page
