mystery liquid - antifreeze or screenwash?
Min
27 Oct 2003
Hi folks
I there any way of telling it the blue fluid in a 2l water bottle is antifreeze or screenwash?
I diluted it a while ago but can't remember which it is :confused:
When I shake the bottle there are lots of bubbles, but does coolant do that as well as screenwash?
It's bright blue if that helps!
Mary
It could be either, Mary - if it has an alcohol smell its more likely to be screenwash.
Get rid, I think.....antifreeze can harm paintwork, and screenwash will dilute any antifreeze in the radiator.
John :)
ok, thanks John
better safe than sorry!
Problem is where to get rid - don't just pour it down the drain if it's antifreeze.
This has come up here (?) before. There's loads of fun to be had reading about it online if you like being confused. It seems there's no "right" answer, and will seemingly depend to some extent on you local council's degree of reluctance to spend money on what would be sensible, like a place to dispose of antifreeze at the local tip, rather than what takes their fancy.
