Hi all,
Am trying to get to the bottom of this question and there seem to be many, many conflicting answers.
I'm putting an 18mm solid wood tongue and groove flooring (Brazilian Walnut/Ipe) down over existing pretty level floorboard. I know that I need to:
- Leave an expansion gap (3-4mm for every metre in width)
- Nail or screw the floor to the sub-floor (which needs to be solidly fixed down)
- Fix in the opposite direction to the floorboards.
- Leave to acclimatise for a week in the room to be fixed into.
The confusing issue is underlay (or not to underlay).
I've had some suggestions that using a 3mm foam type underlay, like Timbermate Excel is a good idea to assist with sound insulation, and prevent moisture from penetrating into the floor from the exposed earth under the sub-floor given it's a Victorian style house where below the subfloor you have a largeish cavity set with the earth below.
The link below shows the sort of suggestion as 'best-practice' that I'm talking about.
http://www.wood4floors.co.uk/guides-and-info/floor-fitting-instructions/
I've also heard this will take away some of the echo and hardness of a solid floor that would exist with no cushioning below.
Elsewhere I've read using a foam type underlay will at best be useless due to the compression as the boards are put down, and at worst will result in a squeak as it could promote movement.
Finally, I've read that under no circumstances if using an underlay over a current wood floor, should one use an underlay with a DPM built in (although the underlays sold for the purpose have these, and there is no explanation as to why a DPM is a bad idea).
So basically, on the question of underlay I'm totally confused as what is best/worthwhile/useless/to be avoided.
If anyone can offer a conclusive or informed opinion on any of the above would really appreciate it!!
Thanks!
Thanks!
