name of the board used to cap the cavity under the tiles
24 May 2011
Norfolk
what is the name of the board that bridges the cavity and which the roof tiles sit on on a gable end called?
also where does the (under tile) membrane finish at the gable end?
is it ok to use a 25x200 ridge board for my hips and butt the rafters to it?
thanks
thanks catlad for the name.
any idea if it ok to use a 25x200 ridge board as a hip and butt rafters to it. it works out to be 3.9m long? if so i assume i would have to brace it or do i need to use 50x200 graded?
Fibre cement soffit strips as mentioned above..
but for gods sake DO NOT copy the overhang on that picture :/ wind would rip that off
The detail is called the verge under-cloak and not referred to as 'soffit' strips.
It can be formed using fibre cement board, roof tiles, bricks etc.
Thanks for your help guys.
:D
