Need waste fitting for shower tray with 90mm hole?
13 Jul 2005
Hampshire
My shower tray has a 90mm diameter hole which seems to be non-standard as I can not find a waste to fit this. Can anyone suggest where I might get something to fit?
Ideally this would do the complete job of fitting into the hole in the shower tray plus has a trap of some type incorporated.
In any case I need to connect to a 40mm diameter plastic waste pipe (ABS plastic).
I wondered if there was not something standard that I have missed if I might be able to use some sort of flanged boat deck fitting?
Any suggestions?
Steve
If you know the make of the shower tray the makers may be able to supply you with a suitable waste fitting.
