new garage
10 Mar 2013
Durham
building a new garage behind my terraced house and looking to build a steel frame so as not to need foundations and disturb the neighbours
looking to build the frame over the old garage then demolish it and lay a concrete base
in using a steel frame I can have a full width garage door without needing brick pillars which would reduce door width
box profile roofing and possible pvc cladding on the sides
do you all think 100mm x 50mm box steel would be sufficient I don't want roof trusses and need maximum height
any help greatly received
Why on Gods gracious earth are you not demolishing the old garage BEFORE starting the new one?
Do you like to make a job really difficult and drawn out?
Becausr i have nowhere to keep supplies the garage will cover the whole of the rear the property
The new garage will be a lean to over the old lean to so will only be 1 wall 2 doors and the roof to remove after and lay a new floor if funds allow
