New Loft
14 Apr 2010
London
Hi
Just had a loft completed by landmark-lofts and the building inspector who was demanding final payment before having performed a final inspection, highlighted that a wooden beam was resting on a party wall that was into the neighbours chimney. So my questions are as follows:
1. Can a wooden beam rest directly onto a party wall that connects into a neighbours chimney stack.
2. Does the wooden beam need to rest on a steel shoe?
As you can see from the picture, they did an awful job and failed to brick up around the steel beam which will be done however I have concerns as to whether this can simply be bricked up.
//www.diynot.com/network/careype/albums/5410
Regards,
Peter
Easy.
Final payment AFTER loft has been past by inspector.
What are they worried about?.....................it not passing?
Andy
Hi
Well it's 3 months since it should have been completed. As the builder was cutting corners in order to line his pockets, I'm now more concerned with whether it's acceptable to have a wooden joist resting on a party wall that opens up into the neighbours chimney stack. They have sent another Team to brick up around this beam and the steal beams but I want to hear from anyone who knows the correct building regs regarding this point.
Peter
No it is not acceptable. Structural timber must be kept a minimum of 40mm from any part of a chimney stack.
We've had a few problems with our loft conversion by landmark lofts also. They completed it a few months back but left our home damaged badly. We had to call in another company as landmark just ignored us. We ended up spending another £8,400 on the repairs.
