New shower - temperature problem
Discussion in 'Plumbing and Central Heating' started by Juliet & Darrin, 3 Feb 2007.
This topic originated from the How to page called Installing a shower.
  1. Juliet & Darrin
    3 Feb 2007
    2
    Thanks Received:
    Country:
    We bought a new shower from 'TradeMe'. It's a Cimarron NR520R (company has gone bust). It takes about 5 mins of fiddling around with the mixer to get the perfect temperature - infuriating! There's about a 1mm range on the mixer between scalding hot and cold. Also the 'massage jets' are a bit pathetic to call jets. We're not sure if we need a new mixer or a pump. Any ideas gratefully received!
  2. Lee-King
    20 Dec 2006
    144
    Thanks Received:
    Hertfordshire
    Country:
    Check the hot and colds are plumbed in the right way round as per your MI's. If it's thermostatic and plumbed in wrong, it will struggle to callobrate to the temperature you're trying to set it to.
  3. Juliet & Darrin
    3 Feb 2007
    2
    Thanks Received:
    Country:
    Just put a pressure reducing valve in on cold. Seems to have more of an equal pressure now. Now the mixer works for about a 3 or 4mm range! Jets still ****y though!
Loading...
Share This Page
