No hot water - Baxi Combi 105e
14 Apr 2014
I have no hot water on the above central heating system. The only way I can get hot water is when the heating is turned on. The radiators are working fine without the hot water but No hot water independently. Any suggestions what the problem might be and will it be expensive?
Diverter valve isnt operating the flow switch. Its stuck r needs replaced. Part it self isnt too expensive
Oh, Really?
Could it not be something a lot simpler AND cheaper?
Oh, Really?
???? What??? Like i said the flow switch isnt operating! So either flow switch r a £20 repair kit, not expensive at all. People like you that offer no help except try and have ago need a good shake
Come on hanns easiest boiler easiest fault check diaphragm first and foremost 99% its that. Fault finding backwards boyo !
Sorry but thats what i meant when saying "stuck" sometimes they seize. Didnt want to go into much detail. The diaphragm isnt doing ist job are the flow switch isnt working. Either way he needs someone in to fix it. All you had to do was correct me ;)
Thanks for your help. I ordered diaphragm from ebay £5.75, which arrived today. I successfully fitted it and now have instant hot water independent from heating.
Maureen.
