no water coming out my hot water taps
Discussion in 'Plumbing and Central Heating' started by glaswegian, 24 Sep 2011.
  1. glaswegian
    24 Sep 2011
    3
    Thanks Received:
    Glasgow
    Country:
    Help! I turned off my cold water supply to look at my shower, it is now back on and my cold water is running fine, sas is my heating, but no water is coming out off my hot water taps. Any ideas?
  2. DeltaT2
    24 Aug 2011
    1,400
    Thanks Received:
    165
    Glasgow
    Country:
    Sounds like an air lock mate. Do you have a header tank in the attic & a copper hot water cylinder? If so my mate Tomplum has a video showing you how to get rid of it.
    HTH
    • Thanks Thanks x 1
  3. glaswegian
    24 Sep 2011
    3
    Thanks Received:
    Glasgow
    Country:
    Thanks, i'm a female and don't know what either are!
    can you explain??
  4. DeltaT2
    24 Aug 2011
    1,400
    Thanks Received:
    165
    Glasgow
    Country:
    Where did you shut the water off hen? Do you have the items I asked about?
    Did you drain a lot of water from your hot water system, like enough to drain your header tank in the attic?
  5. Charnwood
    29 Apr 2011
    3,579
    Thanks Received:
    512
    Country:
    Not knowing what one is, how would she know its capacity?
  6. glaswegian
    24 Sep 2011
    3
    Thanks Received:
    Glasgow
    Country:
    I turned it off under the kitchen sink and turned on all the cold water taps until nothing came out so don't know if that was enough to empty the hot water tank. I have now tried pushing cold water through the hot water tap but it still isn't working.
  7. DeltaT2
    24 Aug 2011
    1,400
    Thanks Received:
    165
    Glasgow
    Country:
    Yes I think you've an air lock on your hot water system. But we/I would still need confirmation of the type of system you have. Can you take some digi photos of your Hot Water cylinder & post them up please?
  8. DeltaT2
    24 Aug 2011
    1,400
    Thanks Received:
    165
    Glasgow
    Country:
    Granted mate, but we do need to establish what system the young lady has.
  9. Agile
    26 Jun 2004
    61,289
    Thanks Received:
    4,285
    London
    Country:
    With her lack of knowledge of even the parts of her system it may be safer for her to call a plumber.
  10. Space cat
    9 Sep 2007
    3,862
    Thanks Received:
    74
    Newcastle upon Tyne
    Country:
    Hot water cylinders are round with a domed top. A typical size might be about 18" diameter and 30" high. They're often coated in a hard foam or, if very old, lagged with some kind of thick material. A common place to put one is in a bathroom cupboard but they can be other places.
    Your cold water tank will be somewhere high up; higher than the hot cylinder and any hot tap (shower head included). If it's not in a cupboard above the hot cylinder, it'll be up in the loft. They're usually rectangular and about the size of a short coffee table. (If there's a second, smaller one it's for your heating.)
    Some cold taps are fed from the tank so that trick won't work with them. :( :( :( You have to use one fed directly from the mains supply. A kitchen tap should always be fed this way.
Loading...
Share This Page
