- Joined
- 27 Apr 2010
- Messages
- 27
- Reaction score
- 2
- Country
hi all, i have just fitted a new oil condenser in place of a 25 year old oil boiler in my house.house size is 5000sq feet double glazed but not insulated well and is draughty, 20 radiators some not convectors and then a coil in the pressurised cylinder.The house is fairly long not wide and the boiler is sited at the very end of the house. the new boiler is a grant with riello RDB 2.2 burner and is set up with a 1.20/80 degrees S nozzle as standard which produces 41.5kw or 142,000 Btu's. All pipes coming from boiler house are 28mm, the old system had four connections, gravity primarys and pumped central heating, now i have 2 pumped with tee off to upstairs, downstairs and dhw cylinder, so three zone valves also. PROBLEM is the boiler cycles about 1 minute 20 seconds on and off for the same, but rads are very hot, and furthest ones are pretty hot too so any ideas why this is cycling? think the boiler is oversized? i can put a 1.00/80 degree EH into the burner to bring it down to 36kw would this be sufficient? the pump is a semi commercial wilo £175 quid jobby it was up full but i now turned it down to middle setting (out of 3) and not sure it made a difference. my biggest question is will this be using more oil starting and stoping so often? ps my thermostat is set at a quarter but even having it on full tilt it'll still cycle like that. CO2 readings are on the button as is the oil pressure.
Thanks in advance if anyone has any ideas, it will be greatly appreciated.
And no smart comments please i deemed competent to fit a boiler as oftec isnt mandatory in northern ireland, just needing advice from somebody who has done a change over to a condenser or who generally knows where my problem lies. many thanks......William
