Has the red burner lock out lamp come on?
You can increase the pressure on your combi by connecting and opening the filling loop, if you know where it is.
John
No it won't work,its 3 years old, I have switched weverything off but still not good,the lock out light is not on. all I did was run the grandchildrens paddling pool while the washing machine was on and the dishwasher,then I notice the pressure had gone down and there was not hot water.
Just spent 300 on it recently having it serviced and am at a loss what to do next.Yes I am blonde LOL.
The water pressure only refers to the central heating circuit, so check that any thermostats are turned up, and the boiler overheat stat - inside the boiler casing - doesn't need to be pressed in to reset.
John
I'm not absolutely certain about this, but combi boilers have things called diverter valves inside - that channel the generated hot water either to your taps or the heating system. They are electrically operated. In some cases if this valve doesn't behave itself, the switches inside the diverter valve may not turn the boiler on. I always thought that the Heatslave didn't apply this though - maybe others will know.
However, there is a lever on the side of the valve, (which has 3 copper pipes going to it) and there is an aluminium box on the top. You could try moving this lever manually and see if the burner wants to start. Be a little patient with it!
Also, when you turn the hot tap on, can you hear a click inside the boiler, which is the flow switch operating?
John
