I was always taught that when joining into a one pipe system, no matter where, tees should be rad distance apart. For instance, if you have one pipe system running through loft space and you hang a 600 rad in room below, tees should be min 600 apart.
Injector tees would help.
Thanks for that. This is how the rads are tee'd downstairs. However where I have tee'd in, in the loft - I am using a flow and return from the boiler. If that makes sense?
