optima compact gen4 alarm
22 May 2014
Glasgow
just fitted a new alarm all things working except external sounder can anyone help
Hi, found this somewhere, hope it helps...
G4 to AG6
Panel / Bell Colours
Stb- = ST- Green
T = -R Yellow
A = V- Black
D = V+ Red
B = SW Blue
The problem I now have, as soon as I power up the external sounder goes
into alarm and pressing the code in does not stop the sounder I have to cut the power to stop the external sounder I have wired it according to the engineer manual
Did you set it up as above and have you put the cover on the AG6 with the screw in, and the panel cover on, both will stop a tamper alarm? This is how mine is set up and working.
I changed the bell box to a Honeywell reason 8 bell box, all wired up cover on screw up still the alarm will not react to the code, I am going to strip all wires out and start again to see if I can find the fault thank for your help
Take picture of connections in panel and post picture on here..the colours biker posted where from his panel , yours may be using different colours..
Looks ok,power up with black wire out in panel bell trip,does it still ring ? Make sure battery link in on and tamper switches closed.
took the black wire out of the bell trig in the alarm panel bell did not ring
when I set off the alarm bell did not ring either, when black wire was returned as soon as powered up alarm bell sounded would not respond to code, everything else works fine,when I take the front cover off the panel
sounder sets off but not the external sounder,when the external sounder is ringing I can set the alarm for pirs and doors and they set
The black bell trip cable goes 0v in alarm , was trying to see if it was the bell box or panel with the issue , so if you remove the black wire ..... Can you set the system ok ? If so set off the alarm .... The bell will not ring BUT the strobe will flash and the internal alarm will sound.... Does it do this ?
