I have just installed a seperate electric oven and hob, without thinking too much I ran a 10.0mm T&E from the consumer unit to a cooker control unit from there I connected it to the hob with some more 10.0 mm cable.I also ran a 2.5mm T & E from the consumer unit which i terminated under the work top in to a fused spur then ran a 2.5 mm flex to the oven (about 2.5kw) . My question is (are) Is this a perfectly acceptable installation ? I wonder because the cooker control unit only switches the hob and not the cooker. How should it be wired if I have it wrong. Should I re label the cooker switch to say \\\'Hob\\\' instead of cooker.
Many Thanks in advance.
Back to top
Back to top
