Paint or replace window
Discussion in 'Decorating and Painting' started by Daddy Boots, 2 Mar 2012.
  1. Daddy Boots
    2 Mar 2006
    31
    Thanks Received:
    Country:
  2. emilybronte
    19 Feb 2012
    991
    Thanks Received:
    121
    Yorkshire
    Country:
    Do you mean replace the whole window?
  3. Daddy Boots
    2 Mar 2006
    31
    Thanks Received:
    Country:
    The whole window.. all parts are in as bad condition. I've got plenty time on my hands, but it would be pointless to spend hours/days on it to have it rotting from the inside out and the paint peeling in a couple of years.
    I suppose the question is...can it be made good from it's current state ?
  4. HERTSDRAINAGE2010
    9 Apr 2010
    6,459
    Thanks Received:
    905
    Hertfordshire
    Country:
    Question: Can you push a key (Yale type) into the wood work approx. 12mm?
    If so then it needs replacing, if not then it needs decorating.
    Andy
  5. misterhelpful
    19 Feb 2011
    3,094
    Thanks Received:
    496
    Ohio (formerly Mid Glamorgan)
    Country:
    HERTSDRAINAGE2010 makes a good point, but even if the timber is solid, you will need to sand all of the grey weathered timber back to a sound surface before you attempt to fill and paint anything. This will also help to give you an idea as to how bad they are.
    I love sash windows and would do my utmost to keep them if possible, but if they are too far gone, I would opt for renewal.
  6. sparkwright
    20 Aug 2009
    5,742
    Thanks Received:
    666
    Dorset
    Country:
    You don't say what your other windows are. Best to match up with others.
    If you scrape off and sand, Sadolin white Superdec gloss may be the answer. It actually sticks to weathered wood and lasts for years. It's water based. Fill any small gaps and cracks before final coats.
  7. joe-90
    28 Oct 2005
    31,290
    Thanks Received:
    1,059
    Country:
    What if he hasn't got a Yale key? Will an Era or Chubb do?
  8. Daddy Boots
    2 Mar 2006
    31
    Thanks Received:
    Country:
    The wood's 130yrs old and still solid.
    Are any of the high street wood hardeners like Tetrion / Cuprinol any good ?
  9. emilybronte
    19 Feb 2012
    991
    Thanks Received:
    121
    Yorkshire
    Country:
    I'm glad you can preserve rather than having to replace (apart from anything else, you'd be required to fit a double, rather than single, glazed unit if you did).
    Sand back thoroughly and fill as advised - any reputable brand of two-part filler such as Ronseal is fine, if it's going to be painted. Only make a small amount up at a time, as the working time is quite short.
  10. Growler
    11 Mar 2006
    793
    Thanks Received:
    50
    Country:
    I've painted windows far worse than this, without a key
    The key to success here Daddy Boots is, with all that time on your hands, don't leave it for another 17 years. A light sand and a coat over every now and then just on the bottom bits will serve you well.
  11. joe-90
    28 Oct 2005
    31,290
    Thanks Received:
    1,059
    Country:
    Growler is spot on. Listen to the man.
Loading...
Share This Page
