I just thought of another question guys.
I'll be using no-nails/gripfill to attach skirting to the bottom of the walls once finished. When I paint the plaster as described above, should I leave a section at the bottom to remain as bare plaster so the no-nails can stick to it? Or should I use the first coat supermatt to go everywhere including behind where the skirting board will eventually go?
I was just thinking that if I painted the whole wall and then tried to stick the skirting baord to it, it might not take properly as its only stuck to the top layer of paint and not the wall directly.
Thanks again
Thanks again
