I've done small bits.. ie where a plank of upvc has gone yellow.in middle of gable...duhhh.. I just made sure it's clean dont abrade and give it a thinned coat of gloss. It was still on ok after several years when I did some more work at the property this year.. Dulux do one specially for upvc.. Not used it myself. so can't comment. http://www.duluxtrade.co.uk/webapp/...KInfoSheet?catentryId=13745&productType=dulux
Can be done, but you need a UPVC Primer. The paint company International do a UPVC Primer.
The primer is especially formulated for use on exterior UPVC, giving superior adhesion for exterior gloss topcoats. It can be applied to UPVC window frames, doors, conservatories, soffits and fascias.
It does say the primer should not be left for more than 7 days before applying the topcoat, as the primer is not weather-resistant.
