pipe
yes as long as you've got enough space inside your wall chase, unless its surface mounted pipework
Don't use it on chrome pipe or you will be :eek: when it blows off in the night :cry:
you will have to change to copper for the last bit, most electic showers need a compression fittinng for final connection
you can use a comp fitting on poly pipe breezer just dont forget the insert and use a copper olive :)
what about earthing issues?
when earthing / bonding its the pipework and fittings, not the water you should be worried about
DOH just realised the thing will be earthed anyway
I am a dingbat of the first water and I apologise
Time for another Vitamin Beer for what ails me
