Im sure the best advice will be to get a sparky in - but I just wanted to see if anyone could give some useful advice before I part with LOTS of money !!
I have just purchased a rangemaster Induction cooker and I think I might have made a mistake !
The orignal cooker (Stoves dual fuel) is on a seperate wiring circuit back to an RCD at the cu (I believe its fused at the CU @ 32 amps?)
The wiring looks like its 6mm not 10 mm.
My question is will 6 mm be enough for the new induction cooker ?
Looking at the installation manual it says maximum power consumption is - wait for it - 17.1 kilowatts !!!
Seems a massive amount to me - but 5 rings add up to just over 9 kilowatts, plus to electric ovens and a grill - maybe its right !
The cu is in the hallway about 15 meters from kitchen - replacing the cable to the cu is going to be a NIGHTMARE taking floorboards up and going under concrete floor (kitchen in extension) etc. etc.
If you need more info to help advice - just ask and I'll try and answer.
Many thanks for your help - it will be MUCH appreciated.
Tony
Tony
