Plinth blocks - Should i give a reveal?
Discussion in 'Wood / Woodwork / Carpentry' started by jackpot, 5 Dec 2011.
  1. jackpot
    3 Nov 2005
    412
    Thanks Received:
    4
    Liverpool
    Country:
    About to install new architrave and skirting and i am using plinth blocks on the doors.
    Question is do i install the blocks flush with the door frame or use a small reveal?
    Arc is 69mm in width, with the blocks 80mm. The arc will obviously sit centre of the plinth block giving 5.5mm reveal if the block is made flush, more they are to have a reveal.
  2. ladylola
    19 Dec 2009
    3,278
    Thanks Received:
    283
    Staffordshire
    Country:
    I've put in plinths in my house. I did it to overcome awful joints at the tops without replacing all the architraves. I left a small reveal on the block of about 5mm and a slightly larger one to the architrave, about 10mm to the edge of the frame , my blocks are larger than yours so the arch's don't sit in the middle. It's personal choice I suppose , I've just never been a fan of fitting things like this flush and without a reveal.
  3. JobAndKnock
    30 Sep 2011
    2,018
    Thanks Received:
    351
    Lancashire
    Country:
    I'd also go for a reveal. Looks better IMHO
  4. steve61
    15 Feb 2010
    51
    Thanks Received:
    6
    Ipswich
    Country:
    I agree...............if you set the blocks back 2-3mm you will get a proper reveal for the archs of 8-9mm.
Loading...
Share This Page
