Hi All,
I have some plinth lights with the following 12v Transformer with a plug on the end.
http://www.ebay.co.uk/itm/281333372...49&var=580368379981&ssPageName=STRK:MEBIDX:IT
My Electrictian has put in a FCU on the wall from the ring main with a trailing cable to the plinth. At the end of the cable there is just a junction box. What is best practice - remove the junction box and fit a socket for the transformer, or cut the plug off the transformer and wire direct to Junction box? If I cut the plug off what fuse should be in the FCU? The same as the plug?
