I am replacing our central heating pump and have a question about the installation orientation.
The new pump instructions say the pump should be mounted with the rotor shaft in the horizontal position - ie the pipe work should be vertical.
Our existing pump (which worked for the last 8 years) was mounted so the pipe-work was horizontal and the pump rotor shaft was vertical.
Can anyone explain the symptoms of mounting the pump so that the shaft is vertical rather than horizontal?
NB, the existing pump still works, and the reason for changing it is that having added new radiators to the heating circuit the hot water is not reaching the furthest away radiator. Wilo suggested a bigger pump (ie 6m instead of 5m) should resolve the problem.
