I am living in the three bed semi detached house with garage converted as a additional room with ensuite bath. Total number of radiators are 8 now after conversion. We have Potterton 10 16 netaheat MK2F 20 plus years old boiler with separate hot water cylinder, never had any problem with heating or hot water since we moved into this property three years ago.
Since i moved in first powerflush was done about a month ago and after powerflush the heating was improved. Now yesterday the boiler stopped working that means no heating or hot water. I hear "TICKING" noise like boiler trying to ignite the system when i switch on the boiler through its timer switch, please note i have setup heating and hotwater through timer switch only. We have no other appliance which uses GAS other then this boiler, also there is no change in the GAS reading on the meter once i turn on the heating system.
I called in engineer who told me possibly GAS Valve not working or possible some control switch. I was told to replace the boiler due to the fact that boiler is old and spare parts are difficult to find. I am not sure if i should replace the boiler just due to this problem which apparently have no solution. And new boiler is going to cost me good amount of money.
My Queries are:
Can this boiler be fixed, where can i find the parts for this boiler?
How much should it cost me to fix this problem including parts and labour?
If new boiler is required can someone suggest viesmann is any good or Vaillent or bosch?
How much should it cost me for boiler replacement only as rest of the rediators and pipe work is fine?
I am based in Reading area so if someone around is interested then please contact me!
Regards
My Queries are:
Regards
